how to find x axis value corresponding to a given y axis value in a graph
Here is my vi again after making the value default.
regards.
Message 11 of 14
(1,256 Views)
You've got quite a bit going on there and I think you're going through a lot of extra work to use the Dynamic Data Types and Express XY Graph.
Here's one way to get what you want though.
From your XY Graph, Index out the first (and only) plot.
Unbundle to get the Y and X Arrays. By a quirk of LabVIEW XY Graph, both of these are named Y. The first one is actually X.
Do an Array Max Min on Y to get the Index of the largest Y value.
Pass that Index into Array Index of X to get the X value.
Message 12 of 14
(1,247 Views)
Also, I don't think your Build XY Graph is configured correctly.
As it is now, you only graph the first channel of your data.
The rest of your data is truncated since your X array is only 1-D 512 elements.
Message 13 of 14
(1,242 Views)
I am not entirely sure if this is what you are looking for, give it a go.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 14 of 14
(1,227 Views)
