how to find zeros in a spred sheet file
I have a spread sheet file having 33 column I want to find  is there any zero in any of the columns,how this can be done easily.searching one dimensional array is time consuming since file size is very large
thanks for your time
regards
augustin
Certified LabVIEW Developer
Message 1 of 11
(3,550 Views)
Accepted by topic author mjaugustin
33 columns by how many rows?
What do you want to do when you find it?  Do you just want to know there is one, or do you want to know where it is?
You could do a multiply array elements from the Numeric palette.  If the result is zero, then you know you've got one.
Message Edited by Ravens Fan on 04-21-2010 10:59 PM
Message 2 of 11
(3,546 Views)
I like Ravens Fan's solution, but you could also take the absolut value of the entire array, get the minimum, and then compare it to 0.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 3 of 11
(3,534 Views)
If the spreadsheet file is a text file, you could use the string functions to search for the presence of zeros.  The details would depend heavily on the format in which the data is saved.
For working with numeric values another caution is in order.  In this case it probably would work to use the Is Equal to Zero comparison primitive, but remember that in general equality comparisons on floating point numbers are not a good idea due to the finite representation in binary and roundoff errors after calculations.  Adapting Matt Bradley's suggestion you might test whether the absolute value is less than some tolerance, such as 1e-6, rather than zero.
Lynn
Message 4 of 11
(3,513 Views)
Lynn
Lynn- good point! but use abs val and compare to the machine epsilon  (that "little e" constant on the numeric>constants sub-palette is the smallest value that the computer can represent as a dbl) Smiley Wink
Message 5 of 11
(3,510 Views)
Jeff,
If the data is being read from a spreadsheet, the tolerance need not be smaller than the resolution in the file.  I agree that machine epsilon is universal.
Lynn
Message 6 of 11
(3,507 Views)
hi
Thanks for the reply
No of rows will vary
I want to know where it is also
Message 7 of 11
(3,465 Views)
hi
Thanks for your reply,your solution works if only one zero is there if multiple zeros are there how i can find the position of those
Message 8 of 11
(3,464 Views)
If you are going to need the positions of the 0's then you are going to have to search. All the above examples where for quickly assessing if there where any 0's present. I would ascertain first, using the above examples, whether you have any 0's. If you do then search for them.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 9 of 11
(3,433 Views)
Just a thought.  Why not look for 0 when you are building your spreadsheet file.  Flag it there.
- tbob
Inventor of the WORM Global
Message 10 of 11
(3,422 Views)
