how to finish FFT analysis (used stereo 16-bit of si read.vi )
sorry! My question was error.
very think you asked my question.
but i couldn't finish stereo 16-bit fft analysis(fft3.vi). see attach files
(2,783 Views)
Bruce,
I am sorry but I do not understand your question. I have seen the VIs and the screenshots, but I am not sure what you are trying to do. What do you mean by "can't finish" The VIs appear to run. Are you getting an error?
(2,783 Views)
I am sorry you do not understand my question,
I want my stereo 16-bit fft analysis frequency spectrum graph(fft3.vi) same as mono 16-bit fft analysis frequency spectrum graph(fft2.vi)-----
in 500Hz, 1300Hz, 4000Hz have three peaks
(2,783 Views)
Hi
I have tried your vis and they run fine. In the stereo one, think you are selecting columm 1 for the two spectrums ( same channel), and one should be 0.
See attached file.
Sorry. Signal was 1000 Hz square
Check the windows mixer settings to see they are correct.
Hope it helps
Alipio.
"Qod natura non dat, Salmantica non praestat"
(2,783 Views)
