how to fix it
(876 Views)
It is internal memry error in run-time. There is no recipe to fix. Probably you can get a little bit more info from report (blue link) or dump from %USERPROFILE%\Documents\LabVIEW Data\LVInternalReports\<YOUR_APP>\<VER>\<ID>
If this reproducible, try to remove parts of code until problem goes away, so you can at least localize it where occurred. Mostly such error like side affect of the wrong called external code, but not only.
(843 Views)
In addition to what has been said, did you send the reports to NI?
What does the program do? Who wrote it? Does it involve third party drivers and DLLs, for example?
(815 Views)
