how to force reinstall of LV 8.6
How do I make a LV 8.6 DVD installer rerun (redo or overwrite) the installation.
My steps leading to this issue - I deleted the Labview 8.6 folder after uninstalling LV8.6. Well something went awry on the subsequent reinstall and thats how I wind up with the DVD not redoing an install. I believe after I swap the Resource Disk for the Installer Disk 1, install Resources, then don't reinsert the Disk 1 installer disk, results in errors or some kind of crash.
NI software does no longer shows up in the Windows "Add Remove Programs" pop up. The National Instrument folder contains 3 folders, "Interfaces", "NI-DAQ" and "Shared".
 Thanks ahead of time.
(2,705 Views)
Try running ccleaner. It can help clean out unused or corrupted registry entries.
http://www.piriform.com/ccleaner
(2,684 Views)
At the end of my install attempt, 8.6 runs License Manager and a pop-up error occurs. See the attached.
Any  soln where I don't have to use a third party tool?
(2,662 Views)
richjoh,
I had similar problems in the past and NI support suggested using MSIBlast .
(2,652 Views)
