how to format a string?
I am trying to format a string using (Concatenate Strings). It works but the last item in the string is shown on the next line.
What I'd like to have is the following :
Time stamp        Label       Value      Result
What I am getting is the following :
 Result
Your help is appreciated.
Regards
Aieman
Message 1 of 9
(4,843 Views)
What makes you think it is producing the result you show? When I run your vi, the file produced is all on one line. Similarly, placing a string indicator on the panel and setting it for \ codes display does not indicate any problem.
Lynn
Message 2 of 9
(4,830 Views)
When I run your vi I get
" 14:09:53.51        Lable                 fail"
Array to spreadsheet string appends an EOL constant at the end of the string, which is why you'd see "Result" on the next line.  To remove it, see the attached modified vi.
Message 3 of 9
(4,829 Views)
Thanks  johnsold and  Novatron
I have Labview 7 so I couldn't open Novatron's file
I have attached the text file of the results to see what I am getting.
Message 4 of 9
(4,822 Views)
string concatenation is nice but I find the string format function more practical for complex concise coding of sting formating issues.  You use this in a very similar manor to printf statements in c is "%s\t%s\t%s\t%s" for a tab delimited string.  Any thoughts here?
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 5 of 9
(4,813 Views)
Oops, sorry about that.  I'm having a bit of trouble saving as a previous version (new to LV 8 - yesterday), but all I did was put a "Trim Whitespace" on the output of the Array to Spreadsheet String.
That *should* solve your problem.  If not, come back and let us know.
Message 6 of 9
(4,812 Views)
Thanks falkpl
I have tried that but it didn't work.
Please see attachment.
Regards
Aieman
Message 7 of 9
(4,802 Views)
Here is a version with the Remove White Space and the Format into String options. I disabled the write to file and just put two indicators (set to '\' Display) on the panel to see what was happening.
Lynn
Message 8 of 9
(4,787 Views)
Many Thanks Guys for your time and effort.
Lynn I have modified your file a littel bit and it did work.
Regards
Aieman
Message 9 of 9
(4,775 Views)
