how to generate Sine PWM in FPGA mode ?
I am currently working on the generation of Sine PWM for the inverter switching control, so I need to know how to generate Sinusoidal PWM in FPGA mode in LabView2015, through Analog Output NI9263 I want to see the output
(3,445 Views)
Did you completed this task? I need guidance on this, How to generate sinusoidal PWM in labview FPGA
(2,845 Views)
Hi yuvi,
Most often you just need a sinewave and a sawtooth signal, as described here.
What have you tried and where are you stuck?
(2,841 Views)
Thanks for your fast reply.
I am working on myrio 1900. I want to generate 100 kHz squre pulse(PWM) by comparing triangular and sine waveforms, then which pin I have to use to take output ( to check in DSO)
(2,836 Views)
Hi yuvi,
You need to use the pin related to the output channel selected/configured in your software!
(2,833 Views)
