how to generate a chirp(linear FM) signal using dds theory in LabVIEW FPGA.
attachment:a sine signal using dds theory. Hope to get some help. Thanks!
(4,007 Views)
you need to increment the "accumulator increment" during the duration of the chirp.  the "accumulator increment" controls the frequency of the DDS cycle.  by increasing it's value, you are increasing the frequency.  the math for increment values follows the same math as determining the frequency to increment value.
Stu
(3,998 Views)
Hi, Did you get your answer. I am in same situation presently, How to generate LFM using FPGA DDS in Labview FPGA. If u get the answer please help me out.. I am unable to generate sawtooth using same method instaead i am getting square wave.
Thanks in Advance..
(3,713 Views)
