how to generate a pwm whose duty cycle has to be varied depending on the frequency of the input trigger??
Sir/madam,
I am quite new to the Labview FPGA module.
I am currently working on an application where i have to generate a pwm to control the ON time duration . The pwm ON time depends on the frequency of an input signal.I want to retrieve the ON time value from a lookup table which contain the duty cycle values for the pwm at different frequencies of the input.This input also has to work as a trigger. The input is pulsed and the trigger has to generate the pwm at every rising edge. I am using a PCI 7831R-  RIO series. I am urgently in need of some help and i have hardly a  couple of weeks before i meet the deadline.
I am trying hard to learn the basics from the shipping examples but not able to quite make my vi work.
Kindly lend a helping hand and i would be very grateful to anybody who can help. Thanks a lot in advance.
Do ask in case of any clarifications required. I  think i have explained my problem quite well.
(2,581 Views)
Hello Manu,
You can refer
Developing a PWM Interface using LabVIEW FPGA or PWM Output with LabVIEW FPGA
How this helps.
Best Regards,
Hardik Asawa
AE
Message Edited by Hardik Asawa on 05-05-2010 12:46 AM
(2,556 Views)
