how to generate an impulse to test the short circuit in an inductor
Im new to labview and i'm in need to perform SURG - SURGE STRESS TEST
The purpose of this test is to detect an inter-turn short by applying a number of high
voltage impulses (or surges) to the selected winding.
Each impulse should produce a sinusoidal transient which eventually decays to zero.
How to generate impulse using labview.
(3,188 Views)
First you need to determine what DAQ device you are going to use to generate the pulse.  What kind of voltage and current specifications do you need?
How are you going to measure the transients?
(3,184 Views)
Accepted by topic author swathi.1356016@srec.ac.in
Hi Swathi,
Please see the function "impulse pattern.vi" in signal processing --> Signal generation pallettes.
Else you can browse through the examples in LabVIEW.
Srikrishna.J
Srikrishna
(3,181 Views)
