how to generate report in excel sheet in without usinsg activex controls, report should contain table , text box , graph in labview?
(2,652 Views)
Hi ashwinich9,
you have to use ActiveX to create some Excel sheets. Even RGT uses ActiveX under the hood...
(2,640 Views)
I guess you don't have many options:
- Use Report Generation Toolkit (that uses ActiveX under the hood, as stated by Gerd)
- Build yourself a OOXML-compliant file (...good luck...)
- Consider a different  format (HTML for the main document and PNG for the images?)
Marco
(2,635 Views)
