how to generate word file in read only format
I am generating a word file using Report Generation Toolkit. I want the word file to be in read only format. Can anybody tell me how to do this using Report Generation Toolkit?
Rajashekar
Message 1 of 9
(4,438 Views)
Accepted by topic author Rajashekar
have you tried the set permissions.vi?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 9
(4,436 Views)
No,
I am not getting that VI. I dont know where it is.
Rajashekar
Message 3 of 9
(4,431 Views)
I hope this is what you want. see here
Message 4 of 9
(4,429 Views)
it is under file I/O-->advanced file functions
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 5 of 9
(4,426 Views)
I have gone through that, there the thing is that the document  is opened through LabVIEW in read only format.
But in my case it is different. I will store all my results or data in word document save and store it in a drive. But I want the document to be in read only format when the user go to the location where the document is stored and opens it in windows. (i.e. set the properties of the document as read only format once i store all the data in the word file)
Rajashekar
Message 6 of 9
(4,423 Views)
Message 7 of 9
(4,406 Views)
Is your problem solved?
Post back if you need something else.
Mathan
Message 8 of 9
(4,340 Views)
Thanks for the help. I got it and my problem is solved.
RajashekarSmiley Happy
Message 9 of 9
(4,297 Views)
