how to get a decimal number from three single byte numbers
i'am in a difficult situation. I have motor which provides me the number of steps moved as three numbers of length one byte.I 'am attaching the program with this message. Here the commands from index 2-4 outputs will provide the number of steps moved. But these are numbers with a single byte length(<256). So how can I get the corresponding decimal number from these three single byte length numbers. please reply
(2,759 Views)
HI perumpadapu,
that's what you posted:
No message, no bytes, nothing that helps to answer your question...
You probably have heard this before: RTFM! Read the manual of your device, as it should note how to interprete those 3 bytes. Once you know that it should be easy to convert the bytes into some "decimal" (INT?, UINT?, SGL?, DBL?)...
(2,746 Views)
Without knowing what motor you are using, I'm guessing that you probably need to use the Join Numbers to combine the bytes into a U32.  The other option is to use the Type Cast function.
(2,735 Views)
continued here...
(2,691 Views)
