how to get a time domain dynamic signal for FFT transform?
Hello, I would like to get a signal of dynamic data type from a graph, with X being the time, and Y the values received with the array. and then I need put this signal into the input of FFT transform, and then can get the frequency result. as the input signal of FFT transform needs a dynamic data type, so it looks not possible to get the result from XY graph. but if I use the waveform graph, I can't get the time value as I expected in X axis. Is this possible to make that with Labview 8.2? I don't find a solution. Thank you. Regards
(2,547 Views)
It seems that it is the same topic. continue here
(2,530 Views)
