how to get an inverse of a scaled amplitude spectrum
I had a signal in the time domain and used the ampitude and phase spectrum.vi to get amplitude and phase information.  The original time domain signal has been lost and I left with amplitude and phase data.
I would be extremely greatful with any help regarding how to reconstruct my original time signal from the amplitude and phase.  I have tried converting phase and amplitude from polar to complex and using the inverse fft.vi but the resulting signal is not correct.
Thanks.
(2,715 Views)
You posted this a long while ago, so not sure if you solved the issue. Have developed some code that will take a previously converted FFT signal and reconstruct it back to the original though it will have lost the original time resolution.
Not sure if this is what you are after?
Regards
Joe
NIUK
(2,644 Views)
