how to get decoration's image
i can get the position ,bounds of decoration use property node , but how to get the image of decoration
(1,876 Views)
Accepted by topic author 8259
Take a screen shot of it.
What are you planning on doing with this image?
If you need to get the image by LabVIEW code, you can create an invoke node called Get Image of the front panel.  Use the position bounds to extract the part of the image array pertaining to the decoration out of the full array.
(1,867 Views)
i want to get the image by labview code , and save it as pictrue file. is there a invode node can get image like button control ?
(1,797 Views)
hope it have a simple way to get the image
(1,796 Views)
Hi 8259,
see message #2
(It's simple and in pure LabVIEW!)
(1,791 Views)
