how to get end value of while loop
i've construct a simple block diagram to illustrate the volume of a tank..the question is how can i obtain the final value of a tank after i stop the operation inside the while loop.
i keep getting an initial value after i stop the operation..thanks for help
(2,967 Views)
Message Edited by Phillip Brooks on 03-04-2010 07:40 AM
(2,955 Views)
Hi shafiesani,
your indicator "Tank1 (%)" contains the last value. Where should another value com from?
Mike
(2,950 Views)
I would connect the shift register output to get the final tank value instead of the loop iterator...
(2,948 Views)
Mike is right. The indicator inside the while loop will give you the final result.
(2,932 Views)
