how to get query without use instrument io assistant
I'm running LabVIEW 8.5.1 on windows 7
I have HP 66000A which has 8 DC power supplies
I want to communicate with the device without using the "instrument I/O Assistant" because I need to allow the user to choose between these devices .
I use the GPIB plates to send the commands
But I couldn't find a replacement for the Query and Parse command to read the output voltage
My address is like this GPIB0::5::0::INSTR
Where the zero can be any number 0-7 (hence the 8 devices)
Message 1 of 8
(3,599 Views)
Hi Mo7,
Did you grab the manual of your HP devices? There you will find any commands needed to communicate with the device(s)…
You may also try the NI Instrument Driver Network to check for pre-made drivers for your device. I found them here
(Hint: I would search for Agilent instead of HP, but hurry up before they change their name again! :D)
Message 2 of 8
(3,588 Views)
Is there a way to use query and parse without using "instrument I/O Assistant"?
Message 3 of 8
(3,584 Views)
Hi Mo7,
I already gave you two ways: read the manual to find all commands (and the device answers) OR use the pre-made instrument driver found at NI.com…
Message 4 of 8
(3,582 Views)
Hi gerdW ,
Thank you for your response.
I don't know but I heard my supervisor told me that the pre-made drivers may slow the execution time since they take longer time to load.
Is that true? If so, is there another way to do it?
Thank you very much
By the way my computer didn't refresh earlier so i didn't see your post sorry.
Message 5 of 8
(3,580 Views)
The manual provides the way for basic language and c language but not LabVIEW
Message 6 of 8
(3,578 Views)
Accepted by topic author Mo7mmed
Hi mo7,
As a programmer you should be able to adapt the examples given in that manual for LabVIEW…
How does the "loading time" influence execution time? Can you (or your supervisor) explain this?
The InstrumentIO-Assistent uses the very same underlying driver to communicate with your device as you would use on your own (or does the driver at IDNet): VISA. "Execution speed" is mainly dependend on the used connection between PC and device and on device execution/response time…
Message 7 of 8
(3,571 Views)
Thank you @GerdW
@GerdW wrote:
Hi mo7,
Thank you @GerdW
Message 8 of 8
(3,553 Views)
