how to get text output based on logical input
I am doing a project on flow control
so I want to display tank empty / tank full display on a LCD display
now how do i show empty / full text based on the % of tank water ?
like when <10% LCD will show empty and when >90% LCD will show full ?
(2,726 Views)
I recommend going through these:
http://www.ni.com/gettingstarted/labviewbasics/
http://www.ni.com/academic/students/learn/
http://labviewwiki.org/LabVIEW_tutorial#External_Links
http://sine.ni.com/myni/self-paced-training/app/main.xhtml (SSP required)
That being said what you are looking for is a comparision function under the...Comparision palette.  Then if the condition is TRUE do something, or if it is FALSE do something else.  For this you can use a Case Structure, or in some cases a Select Function.
(2,721 Views)
Thanks for all the help, i checked out the study materials
but still unable to figure out how to show the text in lcd ?
(2,694 Views)
What is your LCD?  Is this an external device?  You'll have to look at the manual for it.  It is probably a matter of sending it some string data through the serial port.
(2,691 Views)
