how to get the array/matrix of an image?
I solved my problem...
I have just to be careful about IMAQ Create/Image To Array/Array To Image/Display format...
My faults came from type mixing...
Message 11 of 14
(1,286 Views)
Just adding all images will result in overlight isn't it?
A nice example to check is the image average example.vi
This contains the 'add image' and 'image devide' which are handy in your case
Message 12 of 14
(1,283 Views)
Not really, plus or less...
Because I use float when I sum images.
Next I proceed to a dynamic expansion between 0 to 255 ...
So I have a brightness gap and I can process it.
Message 13 of 14
(1,280 Views)
Hi Ju2
I'm glad that your problem have been solve. If you have other question please ask about it.
Best regards
Julio Mena
Message 14 of 14
(1,272 Views)
