how to get the selected rows & columns in the table?
hi everybody,
                     In my application the table is kept inside the event structure.I select the cells  in the table (using mouse) on running time.How to get the selected number of rows & columns in that table?
(5,524 Views)
You can use the "Selection Start" and "Selection Size" properties of the table to determine which rows and cloumns have been selected.
Right click on table on block diagram->create->property node->selection start/size
(5,514 Views)
How to fill the string ('H') in the selected cells when the ring value is changed in the event structure. & how to disable the delete row and column.
(5,500 Views)
You can fill selected values of the table by writing to it or the corresponding property using a property node - the table is just a 2D array of strings.  I think for your "disable" question you are referring to the shortcut menu (when you right click).  If you are using LabVIEW 8.x, you can edit or disable that shortcut menu - just right click on your table at edit time and choose Advanced >> Run-Time Shortcut Menu.
Best Regards,
JLS
Best,
JLS
Sixclear
(5,487 Views)
