11-24-2010 11:40 PM
hi all,
how to give a default file path to a vi..it shold take d deffault file path without a prompt and write the desired string at that location...i gud get the default file path option...but later realised that there is no file created at that location
thanks,
Solved! Go to Solution.
11-24-2010 11:51 PM - edited 11-24-2010 11:52 PM
You can use the Current VI's path then strip it and use the path... See the attached VI its very simple it creats a folder in the VI folder where it is saved...
11-25-2010 12:09 AM
thanx for ur reply....
bt i cudnt open that particular vi. as i have only labview 7 and 8.5...dont have labview 9....
11-25-2010 12:15 AM
Here you go....
Sorry i made the mistake that i was telling the others...![]()
The attached VI is in LV 8.0 (Upto that only i was able to save)....![]()
