how to give complete access to the port of laptop
@ZohaibRamzane wrote:
Now there is another problem. The problem is after runnunig the program , the upper big loop runs and update write to measure file after 8 seconds. But the read from measurement file only reads the updated file only once not always when I push the subvis button.
I want to read the new data every time as it has been updated every 8 sec.
I am pretty sure RavensFan already told you the problem.  Your read is only done once due to it being outside of a loop.
Instead of reading the file, why don't you use something like a Producer/Consumer setup.  The idea is that you use a queue to send the new data to another loop for processing.
GCentral
Message 11 of 15
(1,483 Views)
Is there any simple solution crossrulz?
Message 12 of 15
(1,475 Views)
Search the forum for "producer/consumer".
Click on the New..... link under the file menu.  You'll see templates there for producer/consumer.
Message 13 of 15
(1,466 Views)
I did not get the Solution yet.kindly help me
Message 14 of 15
(1,425 Views)
Please tell me how to give complete access to LabVIEW of port.
The data I am receiving through port is very fast say after 3 seconds. But in LabVIEW, when I plot the waveforms, the waveforms become disturb and not accurate. Problem is in updating the previous data of 3000 array elements of last iteration. As it is slow. Please suggest me something.. Useful
Message 15 of 15
(1,422 Views)
