how to give current output to pxi 6704
I want to check my analogoutput card.I'm using pxi-6704,scb68 board.I have used generate single current on one channel example vi.But i'm getting the error the specified range not---- like that one error.I have set the values using limitsettings control.EVen then i'm getting the same error.
(2,950 Views)
What is the error code that you are receiving? In other words, is there a number associated with the error?
The PXI-6704 can output from 0 to 20 mA. So, make sure you are within this range. Also, the PXI-6704 outputs current on channels 16 through 31 and so make sure you are not trying to use this example with channels 0 through 15 of the device. I hope this helps.
Todd D.
(2,950 Views)
I got it cleared.Now its working fine.Have you worked with the serial port thro'Labview.If so help me in writing a seril application.
(2,950 Views)
