how to handle shortcut key options in LabVIEW
I want to handle the ctrl+c option for a string control in labview. I just want to prevent the user from pressing the ctrl+c button for copying. is it possible to handle that inEvent Structure?
Alagar
Message 1 of 9
(4,798 Views)
Hi Alagar,
can you describe what you try to do? You don´t get the key down event for "ctrl+c" but the key up. Maybe this is enough for you. Another solution could be to write a wrapper dll which hooks the key down event for you.
Hope it helps.
Mike
Message 2 of 9
(4,783 Views)
Alagar
The simplest solution would edit the controls run-time pop-up menu and remove the ctrl-c as an option.
Does that help?
Ben
Message 3 of 9
(4,774 Views)
Ben,
removing the entry Copy from the context menu is not sufficient. In order to disable the control to copy the current active selection, you have to disable <ctrl + c> as shortcut for copying data in the complete LabVIEW environment. You have to open the Tools >> Options, switch to Menu Shortcuts and browse to Edit >> Copy. Switch the shortcut to something else than <ctrl + c>. This will disable the copy function for the shortcut <ctrl + c> (it will occur with the new shortcut of course!)
Drawback:
a) You remove the ability to use <ctrl + c> from the whole LabVIEW environment. So also in edit mode of VIs....
b) When making a selection and then pressing <ctrl + c>, it will replace the selection with a simple 'c'. Most often, this is not intended.
So all in all, i would definetly NOT recommend anyone to alter the shortcuts for common functions defined by the OS (<ctrl + c> for Copy, <ctrl + n> for New Document, .... )
hope this helps,
Norbert
Message Edited by Norbert B on 12-01-2008 08:41 AM
Norbert
Expert: Geometry
Message 4 of 9
(4,764 Views)
Good point Norbert.
Then in that case how about an event for "This VI" >>> Menu Selection ?
The Item Tag will indicate the type of operation.
Ben
Message 5 of 9
(4,757 Views)
If you don't want the user to be able to copy the data from the control, set the control to be disabled.  The user will not be able to select the text in the control.
Message Edited by Matthew Kelton on 12-01-2008 09:10 AM
Message 6 of 9
(4,754 Views)
That will do.
Norbert
PS: The item Tag would be "APP_COPY"
Message Edited by Norbert B on 12-01-2008 09:13 AM
Norbert
Expert: Geometry
Message 7 of 9
(4,751 Views)
Using an Event Structure, you can intercept the Ctrl-C and throw it away, if this is what you want to do (use Key Down? event - the question mark means you can modify or throw it away).  You will need to pass everything else.  Make sure you look at both capital and small "c"s.  I use similar logic to prevent Ctrl-. from killing an executable and to handle things like Alt-F4 when I want a controlled shutdown.
Message 8 of 9
(4,703 Views)
Due to DFGrays reply, i made some tests on this question. It seems that there is a different behaviour if the CTRL + C is captured by <This VI> vs. a certain control. In fact, capturing CTRL + <Any key> is not possible for controls.
Attached you can find a workaround based on DFGrays suggestion.
The issue is reported as CAR #135342.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 9
(4,693 Views)
