how to have a vertical grid lineon the waveform graph indicator for every 10% percent of the maximum X axis value?
how to have a vertical grid line on the waveform graph indicator for every 10% percent of the maximum X axis value, so the x axis will split into 10, the vertical grids line in total will be 11 (including first and last)
Example if the maximum X axis value is 11.56, first vertical grid is at the origin(0), second vertical grid is at 1.156 and continue to last one 11.56
(3,041 Views)
You can use the Range property to do that. Just set the increment value to 10% of the full range. See the attached VI.
(3,041 Views)
sorry i forget to mention my labview is only v7.0 pro
(3,041 Views)
AxE,
Here is a copy of the program posted saved in version 7.0
-JohnM
(3,041 Views)
Thanks John.
AxE let us know if you have questions.
(3,041 Views)
Thanks JohnM and Evan,
the increment work great and i modify it to pass the 10% into "start" too, so it will start at the point of 10% of maximum range
attached file to let people download in future, if they met the similar situation
(3,041 Views)
