how to have two vi front panels on same screen ...?
Hello ..!
I'm running labview in Linux environment. havent faced any problems with it (OS)so far.., Here's what i need to know :I have to vis.., control vi and display vi. I need to get the front panels of both these vis appear on the monitor sideby side at the same time. Also these paired vis must be able to fit screens of different sizes.(15, 19, 23 ). Any suggestions will be greatly appreciated.
Shaun
(2,600 Views)
Assuming that you are using LabVIEW 8.0, the categories "Window Size" and "Window Run-Time Position" under File>>VI Properties should do the trick. You can read more about the features available in these categories in the LabVIEW Help, but they are pretty straightforward. You should be able to set these properties for each of the two VIs respectively and be good to go.
Kind Regards,
E. Sulzer
(2,565 Views)
