how to hide only pause button on toolbar in run time
hello,
I had hide all the buttons like run, run continuous, abort vi and others by navigating to VI Properties and unchecking the corresponding options.
when i run the vi, all becomes hide except pause button and i didn't find any option for hiding it manually as well as programatically.
can any one tell me how to hide pause button. i have an urgent requirement for same.
Thanks & Regards,
Samriddh Sarbalhi
Message 1 of 11
(5,690 Views)
Accepted by topic author samriddh
You need...
VI Properties --> Execution
Disable "allow debugging"
Rod.
Message 2 of 11
(5,681 Views)
hello Mr Rod,
Thanks for the solution. I tried and it worked.
Have a nice time.
Thanks & Regards,
samriddh sarbalhi
Message 3 of 11
(5,674 Views)
Rod wrote:
You need...
Rod.
Or, simply uncheck the "Show toolbar while running" option in VI Properties > Execution category. Smiley WinkSmiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 11
(5,671 Views)
There is no such option in LabVIEW 9.0 or higher.
Message 5 of 11
(5,250 Views)
I'd like to hide the toolbar with the Run - Run Continuously - Stop button during run-time. I have disabled the Allow Debugging option in File > VI Properties > Exection, however the tool bar is still showing.
Any suggestions? My version of LabVIEW is 9.0.
Message 6 of 11
(5,246 Views)
Why would you disable debugging instead of unchecking 'Show toolbar when running'? It's easily seen in  'Window Appearance>Customize'
Message 7 of 11
(5,235 Views)
I just found that the option called "Show Toolbar When Running" is located under VI Properties > Windows Appearance > Customize. I disabled it and it worked. Thanks!
Message 8 of 11
(5,229 Views)
So, the option I mentioned is still available, but only at a different place. Smiley Happy
I was shocked on seeing your earlier reply, "There is no such option in LabVIEW 9.0 or higher.". Smiley Surprised
Message 9 of 11
(5,217 Views)
As far as I know, the option has never been selectable under the 'Execution' category. Attach a screen shot that shows that it was ever different.
Message 10 of 11
(5,212 Views)
