how to highlight common item from two list boxes
Hi All,
I have generated 2 list boxes (listbox1 & listbox2) by parsing two simillar.csv files.In runtime if i click one item from listbox1 then similar item
from listbox2 is to be highlighted and selected .Can this be done by mouse click events? Please suggest the correct method to do this
I  have attached my application for reference .
Ajesh
(2,401 Views)
Hi Ajesh,
you can simply add a property node of the listbox2 in your value change event of listbox1. Use the value property and connect the value from listbox1 to the value from listbox2.
Mike
(2,400 Views)
