how to implement an OR condition for 2 strings?
hello, i have external flash memory data coming from serial port to LV, and i would like to sense when the incoming data ends. In my microcontroller code, i have assigned an EOS characters (to mark end of data), however, I would like to check if EOS has arrived OR a continous FFFFFFFFFFFF is sent from flash mem(indicating there is no more data in flash). how can i perform ORing of these two strings?
Now on LabVIEW 10.0 on Win7
(3,845 Views)
Well, a "continuous string of FFFFFF..." is difficult, because you would need to wait forever to ensure it is continuous. 😄
You need to decide how many continuous FFFFF constitute a termination event. Do you have a good guess?
In any case, once you decide how to detect the condition and output a boolean, a simple OR from the boolean palette will do. The other condition is the presence of EOS (what character is that?).
(3,835 Views)
hahaha... altenbach, i shoudl have mentioned about the FFFFF, well, i am checking if 10 (FF)h are observed or not... that shuold be good i guess...
the other EOS is (St~P) ... i made it complex so that lv doesn't get confused the EOS with actual data...
(3,811 Views)
10 (FF)h?  What do you mean.  10 consecutive Fs?
Is this just another method you are using to signal EOS?
Why do you need two different EOS flags?  Just use the EOS character to determine the end of transmission.  Please clarify what your intentions are.  Posting your VI would be helpful.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(3,784 Views)
Accepted by topic author LV_Enthu
After studying your post, I clarified my own question.  See attached.  As was stated earlier, you will need to determine when the 10th F is received.  You could simply output a boolean to the OR gate once you have received enough Fs or a string like in my example.  Your choice.
(3,767 Views)
