how to implement if condition
Hi all,
  I am doing project on Labview. my doubt is how to find weather the given number is positive or negative. and how to implement 'if' condition in labview.
Message 1 of 9
(4,246 Views)
Labview has function blocks that implement features like "Greater than or Equal to Zero" on the comparison pallette.
"Returns TRUE if x is greater than or equal to 0. Otherwise, this function returns FALSE."
That might be a good place to start.
Also check out the free tutorials- it will save you a lot of time and frustration.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 2 of 9
(4,228 Views)
For your current application you can make use of what steve has mentioned.. In general, you can use case structure to implement if or if-else conditions..
Message 3 of 9
(4,225 Views)
Something from here would work for you also.
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(4,178 Views)
This can be used to check if the number is positive or negative
Message 5 of 9
(4,121 Views)
Interesting.  You borught up a valid point.  "Not negative" is NOT the same as "positive or negative" - which implies "NOT zero," since zero is neither positive nor negative.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(4,087 Views)
Here's a simpler way to do the same thing.  The three cases are "..-1", "0", and "1..".  The ".." gives a range.  So in this case "..-1" is all numbers -1 and less (aka, all negative numbers).
Message 7 of 9
(4,078 Views)
Many times you can avoid case structures entirely, with the advantage that all code is visible at the same time. This makes the code understandable and self-documenting, even from a simple, flat code image alone.
Here's what I would do.
 (Compare this for example with the code of dprathima14 above, that has stacked case structures and three different dialogs that cannot be distiguished without double-clicking them)
Message 8 of 9
(4,058 Views)
As always, leave it to Altenbach to show us all up.
Message 9 of 9
(4,044 Views)
