how to import files from specific directory
hi
how can i import files from specific directory ?
in this directory there is 5 files which they change every 10s ..what i need to know is how can i import these files into labview in specific order and do that again after 10s to get the new files ??
these files are saved from the command line using tshark commands
ia using wind xp and labview V8.5.1
thanks
(3,247 Views)
You can do it. What format are they in? All you should have to do is go to the file palet and look for the vi's that I have attached.
Tim
GHSP
(3,244 Views)
Duplicate post.
The wording of the question is different but the topic is the same. It would be best to continue in that thread since you've already had several responses regarding this topic.
(3,240 Views)
thanks aeastet for ur help
but if u can give me an attachment to test it that will be great ..
(3,216 Views)
What do you mean by attachment? All of the VI's that I used for this are on the file dialog under the avdaved tab for the folder info. You should be able to easily replicate this vi.
Tim
GHSP
(3,214 Views)
