how to improve sampling rates in mega samples spartan 3e board
 I am trying to acquire data in spartan 3e board in mega samples rate can you post me any examples for this purpose
(3,134 Views)
Are you successfully sampling at a specific rate currently? If so, what is the sampling rate? Also, what frequency do you want to be able to sample at and are you reading from a digital line on the Xilinx board?
Best,
tannerite
Tannerite
(3,109 Views)
If you're trying to get analog samples in that range, the issue that you're going to run into is that that sort of sampling rate is right at the bleeding edge of what you're asking for (it's a 2-channel @ 1.5Msps chip, the LTC1407A-1). If you actually want to capture at these rates, you're going to need to pull some interesting LV-foo using single-cycle timed loops in the FPGA diagram or drop some code down into an IPNode/CLIP Node, with outputs from those IP blocks hooked to the IO in a SCTL.
Please let us know a bit more about your specific design.
-Brad
(3,083 Views)
I would post some code, but unfortunately professional programmers are not allowed to use the lower priced hardware with the software they have purchased.
(3,071 Views)
Correct, the Spartan 3E is only intended (and licensed) for use with use with LabVIEW for academic users/institutions.
(3,064 Views)
Accepted by topic author discussion_forum
Up to now I success to get sampling rate in Kilosamples but megasamples requires complex code
(3,027 Views)
