how to include MATLAB custom program to LabVIEW
Amaka,
What would you want to connect between the DAQ assistant and the DAQmx read?  They both will perform the same function of acquiring the data.  If you want to convert the dynamic data from the DAQ assistant, you can use a From DDT VI.  It is located under the express palette on the block diagram.  I hope this helps.
Brian Coalson
Software Engineer
Message 11 of 11
(657 Views)
