how to include an instrument driver with the Arduino LINX program?
I have made a program to control the Arduino and it works very well, and I need to include the Fluke45 driver within the Arduino LINX program... So I put the fluke driver outside the Arduino while loop as shown below :
The problem is when I start the execution , the driver is expected to be in continuous tirggering (it shows the measured value continuously) but it doesnt work as expected( it shows only one value and then stops executing) . Note that when I separate the two block diagrams,  the driver works as expected. And I need to have them both in the same Front Panel.
How can I solve this issue?
Can I use the two block diagrams for the same Front Panel ? or is there something missing in my program ? or Do I need another while loop for the driver? It may be a simple question but I am struggling.
(2,660 Views)
The code for the fluke needs to be in the same loop or in its own so that it executes more than once.
(2,599 Views)
