how to increase intensity od an image
hello
I used a XY graph and saved by jpeg format but in black and white. I used write to jpeg palette. Graph 's one of the property node options is image depth. If we set this by 1 we get b&w picture with major axxis is only visible. how to change the depth of the picture.minor axis is not visible in by setting of 1 in depth of image.
how to visible the minor axis of the XY graph
please help me
"Thanks with regards "
by
..........Gireesh..........
(3,897 Views)
Hi Giresh,
either use a higher bit depth of 8 (or 24)
or set all axis (and other) settings to values giving you a proper bw graph...
Message Edited by GerdW on 04-29-2010 07:32 PM
(3,891 Views)
helo sir
thank u for responding
If we use 8 or 24  it shows colour images.this colour images cannot take any print out.  i  need bw pictures with showing minor axis also in x axis. in x axis it will not show or save minor axis. how to increase minor axis image depth. i need a graph like, if we make a graph in excell like that.how much you understand I don't know. now I had o data to show.
thank u
by
(3,868 Views)
Try this, I think it might work for you. It's not the fastest thing in the world, but it does what I think you are asking.
(3,848 Views)
hello
this vi is not opening due to higher version of LV
I am using LV7.1. otherwise you give an image of block diagram. please
thank u
by
(3,837 Views)
Hi COsiecki,
there is no need to use loops.
Mike
(3,825 Views)
Hi Giresh,
pick the coloring tool (called "brush") and color your graph as you like (and need). You could make x axis markers black and use white as graph's background color. After you have finished that "art work" you can also print your results in BW Smiley Wink
(3,821 Views)
