how to increase or decrease speed of Windows media file in vi?
hi......
           I have just started learning LabView8.5. I want to control frame rate of a video file (.avi file).  Is it possible??? As of now i have just opened mwdia file and played it...
        - Thank You
(3,359 Views)
Will this helps?
(3,329 Views)
Thank you very much .. its working...
(3,299 Views)
Glad it works.
BTW, if you are sure could you please mark the solution as accepted solution so that other users searching the board for the similar kind of questions, will see this one as solved and it might help them also by saving their precious time.
Mathan
(3,296 Views)
