how to input two commands to the same serial write which is inside for loop.
I had a for loop with basic serial write and read VI. I need to put  nine commands one by one to the serial that' why I used for loop for inserting the commands. So I had put a build array  anad inserted commands one by one.. So If I want the index 4 command to be adjustable with the condition how can I put such a thing. Can You please help me.
(2,710 Views)
What does it mean ---'want the index 4 command to be adjustable with the condition'.
What you want when condition is TRUE ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,707 Views)
yes I want 4th command to be adjustable. Means the fourth command to be 125 when that case is true . It should be 175 when other case is true. This is my intention I'am sending it as a VI
(2,697 Views)
You can manipulate like this
--Ranjeet
(2,694 Views)
STOP DOING EQUAL COMPARISONS ON DBLS!!!!
______________________________________________________________________________________________________________________
It does no such thing.
(2,665 Views)
