how to insert 1D array to mysql database
HI all,
I have 1D array like in the attached file, after inserted this array to mysql database and I want to read it again.It looks like in the photo q2!! I was wandering if there is someone can help me to read it again as I inserted (1D array) and not like a one cell. Thanks in advance
Regards
(5,222 Views)
You insert not array of numbers or strings, but single string.
First of all you need understand what you want: string, array of string or array of dbl.
(5,189 Views)
Hi artem,
Actually , I want to insert array of dbl and read it again as it is.. how can I do that? thanks in advance
(5,179 Views)
You need to insert the numeric array as a BLOB (binary large object).
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,169 Views)
please bear my ignorance, can you explain more?
(5,153 Views)
Is this a MySQL forum?  http://forums.mysql.com/
Take some tutorials.
(5,143 Views)
