how to insert VI from library to function palette?
Hi all,
  I create a project to compile bunch of VIs as lvlib and only export some libraries as public. I wonder how can I export the public VIs into the function palette? I try [Tools] -> [Advanced] -> [Edit Palette Set], I create a new Palette but when I insert VI by selecting the lvlib, it doesn't import the exported VI. I wonder if there is any way I can import the public VI from a lvlib into the function palette. Thanks.
(4,446 Views)
Accepted by topic author dragondriver
@dragondriver wrote:
Hi all,
After trying for hours, I finally find the solutions.
(4,402 Views)
And how did you do finally?, could you explain, please?
(3,916 Views)
A little late, but perhaps this helps someone else.
On the toolbar click on Tools >> Advanced >> Edit Pallete Set
You can add/erase/edit icons or sub-palletes in here.
(3,899 Views)
