how to insert data to the specified row column of the multi column list box
Hi All
How do i insert data into the specified column of the multi cplumn list box?
I have a table that containsall station nos and name.Then another table contains the data the various stations having at  for 24 hrs.That is 12 am to 11 pm.
And i want to display each stations details as follows using a multi column list box/table
My stationinfo table
stnno   stnname......................
s1           stn1
s2            stn2
s3             stn3
The other table
stnno      sysdatetime       data
s1             12am                   1
s2              12am                   4
s1               1  am                 2
So the station s1,s2.... will have data for 24 hrs.
And i want to display it as follows using a multicolumn listbox
stnname        12am   1 am ......................................11pm
s1                   ...................
s2                 ........................
What i have in my  mind is to get all station nos
and in a for loop get the station's data from 12 am to 11 pm
or
select every statios data for each hor.But in this case i have to query the database 24 times.So i dont think its a good way.
Or any other better query available?
Can anybody suggest me a good idea?
One more thing...how to insert data into the specified field row or column of a multi column list box?
Thanks in advance
(3,406 Views)
hi
i want to know,,can u say ur need clearly...and i attached two image u see that one
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
(3,400 Views)
hi
 u can use property node....... just convert what u want to insert into the table to string format and then as shown in the diagram u can insert in to the multicoloumn list box....the multi.col.list box is in the format of 2 D array so that u just give the index of row and column and  using insert into the array u can insert where u want .. i think this help u ,,,,,,ok further u a having doubt send to me....ok
Indrajit
(3,399 Views)
Hi Indrajit,
Thank u so much 4 the timely help.
I will try and if any doubt i vl get back 2 u.
thanks one again
(3,376 Views)
