how to install Hardware Input Output examples in LabVIEW 2014
I have an issue with my LabVIEW 2014 re-install on WIN-10.
The example finder doesn't display any Vi's in the Hardware Input Output folder, and other folders seem to be short of examples as well.
Does anyone know what the problem is?
Thanks for any assistance,
Joel
(4,139 Views)
Can you show a screen shot of what you see under the NI Example Finder?
-ncm
(4,131 Views)
Also, what drivers have you installed?
-ncm
(4,128 Views)
I attached the screen shot.  When I select the SETUP option in the Example Finder, I select to show examples in both the LabVIEW, and CVI.
Only the CVI examples show up.
(4,121 Views)
I have noticed when I chose a specific type of example, I will have limited examples to choose from with Hardware Input and Output.  I select 'No hardware chosen'  to show all the examples that I would like.  Can you try that and see if it helps?
-ncm
(4,111 Views)
The screen shot was with the "no hardware" option selected.
It seems like the re-install failed to install the LabVIEW examples.
How do I install those examples?
(4,106 Views)
I am not positive, a lot of times I have to do another uninstall and reinstall.... that takes too much time!!!  Here is a link to the examples, plus a lot more, online: ni.com/examples
-ncm
(4,100 Views)
