how to interface sit with matlab 2010a and labview 2010
i am using simulation interface tookit 5.0 with matlab 2010a and labview 2010, i want to take my signal from matlab to labview but during transfering signal i am facing a problem. I want to know is there any compatiblity issue in sit 5.0 or am i doing something wrong?
pictures of errors are attached.
Message 1 of 12
(4,989 Views)
is it true? LabVIEW Simulation Interface Toolkit does not support 64-bit versions of the MATLAB and labview application software.
Message 2 of 12
(4,988 Views)
I wouldn't be surprised that SIT doesn't work in 64-bit, NI now offers VeriStand so I don't know if they'd upgrade SIT to 64bit.  I haven't used LV2010 in a while but one huge upgrade has been the underlying LabVIEW Compiler, there has been significant amount of improvement in performance so you might want to look into a newer version of LabVIEW or VeriStand if that's a possibility.
-BTC
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
Message 3 of 12
(4,955 Views)
I don't see your signal connected for proper probing, looks like you've simply connected one Simulink component to the other in that image, but I don't see an I/O connected to that wire (which is what SIT scans for to detect signals and then read them)...  Take a look at the attached snapshot of a Simulink interface... if you drop I/O connector on the diagram, give it a label, and connect to your existing wire then you should see it come up in SIT.
We have used SIT to import & run MATLAB/Simulink S-files on PXI a while ago, as far as I could tell if you setup MATLAB file properly for signal probes, SIT had no issues reading the signals. I am not positive but look into the type of data that you're connecting to Signal Probe in Simulink. If I recall correctly, they all had to be Double (also keep in mind Endian order).  I don't have SIT loaded at the moment so can't tell you for sure...
-BTC
Message 4 of 12
(4,949 Views)
http://digital.ni.com/public.nsf/allkb/02F5FA55FC28BDE1862578A30071F975
While that's for 2011, I doubt they decided to remove 64-bit compatibility as they went forward seeing as 64-bit became more of a demand rather than less.  In that document, "Note  The LabVIEW Simulation Interface Toolkit does not support 64-bit versions of the MATLAB application software."
As far as compatiblitly for 32-bit, I'd take a look at: http://digital.ni.com/public.nsf/allkb/D174674A91E5536286257428005C2426
Message 5 of 12
(4,903 Views)
Accepted by topic author toqeer.rauf
OP's question was regarding SIT support on 64-bit version of LabVIEW and 64-bit version of MATLAB/Simulink software itself, not the operating system.
Document in your second link is on a completely different topic of API inter-compatibility of LabVIEW & MATLAB/Simulink/RTW (well, mostly Simulink & RTW). Here's the relevant link for 32-bit compatibility: http://digital.ni.com/public.nsf/allkb/049295038FF0EE2A86257A06006B2DAD  there is no 64-bit SIT.
Another underlying issues is that Pharlap doesn't have a 64-bit version. Simulations are eventually better run on RTOS (PXI embedded controllers) for a deterministic performance rather than PC operating systems.
-BTC
Message 6 of 12
(4,890 Views)
Thanks for your reply,
I am now working on 32bit MATLAB(2010a), i got my signal on MATLAB using SIT without any error but cannot get it on LABVIEW..  is it still an issue with compatibilty or something else?
Message 7 of 12
(4,869 Views)
How are you trying to get your information from your code into LabVIEW? Are you compiling your code into a model and then calling that in LabVIEW, or are you using some other form of communication?
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
Message 8 of 12
(4,772 Views)
i am creating model in simulink and then calling that in LabVIEW through simulation interface toolkit..
Getting an attached error in labview during transfering signal from matlab to labview
Message 9 of 12
(4,765 Views)
Are you trying to call this model on your Windows PC, or from a Real-Time target?
Miles G.
Message 10 of 12
(4,740 Views)
