how to invert rotation of a bipolar stepper motor
Hello, i have this very simple program that starts a stepper motor. I want to be able to invert the rotation of the motor... how can i do it?
The motor is connected to a MyRIO 1900.
Thank you
Message 1 of 11
(1,426 Views)
Hi Depi,
with just one pin/DO you can only control the speed, but not the direction…
Read the manual of your stepper motor!
Message 2 of 11
(1,424 Views)
So, how can i do it? i don't have any manual...Can u help me?
Message 3 of 11
(1,418 Views)
You need the manual. The motor should have information on it. When you search for the manufacturer and serial number, you might get the manual.
Message 4 of 11
(1,405 Views)
ok, here you have the manual
Message 5 of 11
(1,395 Views)
How to reverse rotation direction
Message 6 of 11
(1,387 Views)
I'm not understanding how to invert the rotation without changing the link of cables.... can u give me an example of code?
Message 7 of 11
(1,382 Views)
Hi depi,
your motor comes with 6 wires according to your datasheet, you don't need to rewire them to have the motor turn in the other direction!
You need to output signals/current to the right wires to define the direction. For this you probably need more than just one digital output…
Message 8 of 11
(1,377 Views)
ok thank you, so i have to link black green red and blu cables to vcc and GND. yellow and white cables to a digital input?
Message 9 of 11
(1,371 Views)
Hi depi,
I would link YEL/WHI to either GND or Vcc and switch the other wires/windings as needed…
Message 10 of 11
(1,360 Views)
