If you look under the functions palette and under communications>> you will see a function called system exec. This function will allow you to run a program like you would through the command prompt. Unfortunately I don't have 6.1 installed anymore so I cannot provide and example. if you have any other questions let me know.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
