how to know the time elapsed
hello all,
iam new to using labview and would like to have some tips on how to know time taken by my program or design to complete execution
Message 1 of 11
(5,189 Views)
A simple approach would be to do as shown in the pic attached
Hope this helps
regards,
Dev
Message 2 of 11
(5,182 Views)
thank you dev,
but do you think using sequencing is a good approach when designing large applications
with regards
vijay
Message 3 of 11
(5,177 Views)
Hi Chander,
good question, but you state in your first post that you don't know much about LV (we all did once, truly) and then in the second post you mention large application. I need to warn you if you want to make a large applicatoin don't RELY on these forums. They are very usefull, but we can't do your work. If you want to do a large application AND you are a fresh labviewer attend some courses (basic I&II to learn LV and intermediate I to write large applications). And off course experience, experience experience.
Good luck,
Ton
My LabVIEW Ideas
Message 4 of 11
(5,176 Views)
thanks dev,
its true that im new to labview,
im not doing any large appications as of now.
the reason y i asked about large applications is that while reading through the discussion forums  i learned that sequences are not a good style of coding thaty i asked it.
presently iam doing only basic designs and have no plans for large applications in this early stage
with regards
vijay
Message 5 of 11
(5,172 Views)
thanks ton,
with regards
vijay
Message 6 of 11
(5,169 Views)
Well Vijay,
Sequence or no sequence, the funda of getting the time elapsed in execution of program would be to query and note 'tick count' at the beginning , query tick count at the end and subtract tick count at end from tick count at beginning
Message 7 of 11
(5,162 Views)
Hi Vijay,
Just as devchander pointed out, the idea is to take a timestamp at beginning and and the end of the running program and calculate the time difference. I have attached a sample code [Timing Template (data dep).vi ] that serves as a template for calculating LabVIEW execution time. This example can also be found in c:\program files\National Instruments\ LabVIEW X.Y \ Examples\ General \ structs.llb
Tunde.
Message 8 of 11
(5,134 Views)
Off Topic,
but I knew it was just a matter of time until devchander would respond to one of chander's posts!happy smiley
Message 9 of 11
(5,128 Views)
thanks for the reply
i couldnt reply soon because of weekend
with regards
vijay
Message 10 of 11
(5,095 Views)
