how to know when the voltage is over the X-axis
I've been away from this thread, so you'll also have to refresh my memory.
Message 51 of 55
(1,052 Views)
Ok Ray.R
Don't worry.. in my last post I post all the Vi's and all I have
so you can work on that and help me with something =D
Message 52 of 55
(1,047 Views)
Well so I will try to explain it to you.
Well at the first moment I have a file that record 7200 samples and show it to me in 1 to 1 sec, when I run the converter on that file, it gives me only 1 graph with all the time I measure like, When I select Voltage and Current it shows me a unique graphic since I started to monitorate until I finish.
But my problem is, When I convert, this new file in the end the values don't matter with the original file.
So I think something at my logic is wrong.
I will upload all the VIs you will need to make that!
Take a look, and maybe you can help me!
Message 53 of 55
(1,038 Views)
I will try to look at it this afternoon
Message 54 of 55
(1,030 Views)
Don't worry Ray, When you have some free time =D
Thanks for your help
Message 55 of 55
(1,017 Views)
