how to let cursor move with the changing curve, but its Y axis stays the same?
for instance, each time i do data acquisition, the curve changes, it will always cross y=1 at  one point.  i need to show this point automaticly each time finish acquisition, in order to show its x value.
Many thanks!!!   ^.^
(2,755 Views)
Right click the waveform graph in block diagram -> create -> Property node -> cursor -> cursor position -> Cursor Posx
Because you know the curve, you can specifiy the Cursor PosY also.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(2,743 Views)
Thank you! but...seems somewhere wrong with my program, PosY of the cursor is still not fixed....
(2,730 Views)
