how to load program on pxie5641
I am new to labview.
I want to load (burn) labview program on NI PXIe 5641  card.How I can do this?
Pooja
(2,653 Views)
First you should become familliar with LabVIEW, (Read the help, do the tutorials, take the on-line self-paced training....)
Then you will need to learn about the LabVIEW FPGA module that allows you to develop code to run on an FPGA target.
And then you sould be able to read about IF xcvrs and how to use LabVIEW to interact with them.
This really is a daunting task for a beginner...  Consider working with an Alliance Partner to help with the learning curve and avoid common misconceptions about programming at this level.
(2,646 Views)
Thanks Jeff!! Currently I am learning LabVIEW and doing tuto  and all.
But can you please tell me    how I can proceed for LABVIEW FPGA and hardware part practice parallely?
Please let me know if you can suggest some good in detail roadmap for me?
Thanks in advance.
Pooja
(2,629 Views)
