how to localize the items in the combo box which are changing on run time
HI all,
I am using the LabVIEW localization toolkit to change the front panel text of my GUI's into different languages . IF i am having the static items in my combo box their translation can be defined in translation table and hence it can get converted.
But i am not able to translate the items in the combo box which are changing in run time. How to define tags for such items?
if anyone knows plz reply...
thanks...
(3,029 Views)
Hi LV Again,
as far as you need to compile Language files statically, you need to use some workaround to solve this problem.
I have contacted producer of LTK (Labview translation toolkit) and asked him for help in this matter. If I receive any response, I will post the reply.
Kind regards
Marek Santavy
(2,986 Views)
You should be able to use the Strings[] property to change/localize the items in the combo box.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,979 Views)
You can meet this requirement using the Strings[] -Property of the combo box element. To achieve this build the list of items in block diagram and translate them using the "Translate Text" API function of LTK.
Please refer to the example attached.
Note: every new entry in the list will be added automatically. You need to update the content of the translation table and recompile the language files afterwards.
(2,975 Views)
thanks for the reply...:)
(2,924 Views)
